You didn’t specify how far you got after swithcing it on.
You could try Performing a Start-up Repair:
The first thing you can try is booting into the recovery environment, if possible, and then performing a start-up repair.
To access the recovery environment, turn your computer on and off three times.
While booting, make sure you turn off the computer when you see the Windows logo.
After the third time, Windows 10 will boot into diagnostics mode.
Click Advanced options when the recovery screen appears.
Click Troubleshoot.
Click Advanced options.
Then, click Start-up Repair.
If you can’t get this far your hard drive may be corrupted
If so try booting with a USB flash drive with with the Windows installation files on it, as drmdolfan suggests.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
1 Kommentar
If you can get to the BIOS, try resetting and also try booting up from a USB.
von drmdolfan
