Flashlight and magnifier app don’t work.
I replaced my rear facing camera, which solved the blurring and focusing problems, but now my Flashlight, Magnifier and Portrait mode do not work. Thank you!!
Ist dies eine gute Frage?
The flashlight will typically disable itself if the phone detects a fault, are both cameras definitley working?
War diese Antwort hilfreich?
I’m not completely sure. The camera works better in my IPhone 7 Plus,but Portrait does not work, nor does 1x. I can only take photos on 2x. I appreciate your thoughts, as I don’t know much about this subject. Is it possible that the replacement camera I received was defective or is this a different issue all together?
1x - does not work
Magnifier- does not work
Portrait- does not work
Flashlight does not work
yeah, if the 1x isn't working that will cause the others to stop as:
Magnifier uses both cameras
Portrait uses both cameras
Flashlight will disable itself if it detects a fault
New camera should work otherwise you may have a logic board issue
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 115
