Need help to identify if the screen cable order is corrected linked.
TLDR:
(click to view full img)
The issue is after the back light has been burnt, I need to weld them to alternative point by jumpping wire. Am I linked the cable order correct? or incorrect in some links like the graph showing below?
(Also I am not confident for 1-10, the link 5 maybe also wrong since it does say ‘not connected‘ in the boardview.)
Long story: I splitted a cup of water on the top left corner and watched the screen flashed into white and going off in under 0.1s. I think the screen may burnt.
After checking the logic board I found the burt area like the image shows, the two red line area is together the back light. So until now I only can try to weld them to an alternative point, if it does not work it means the screen is burnt as well: It is no worth to repair if so.
Ist dies eine gute Frage?
