Zum Hauptinhalt wechseln
Veröffentlicht am 21. September 2018. Modelle: A1921, A2101, A2102 und A2104 / Erhältlich als GSM oder CDMA / eSIM oder nano-SIM / 64, 256 oder 512 GB / Silber, Gold oder Space Grau (Ausgesprochen „iPhone 10 S Max“).
Reboots every 3:08 Minutes.
Phone was updated from iOS 13 to 14 and, since then, has begun to reboot every 3 minutes.
Though there were no issues prior to the update, rear housing has been replaced and all parts are original except for the screen.
Have attempted:
  • Placing back the original screen
  • Removing the sim card
  • Booting it with all cables unplugged(including either the power or charge port cables)
  • Formatting through PC
The screen glitches just a bit prior to shutting down. Small greyer line in the bottom and flashes a bit. It looks exactly like a hard reset, actually. Performance is also noticeably slower. It doesn’t reboot when locked and idle. The phone is also peculiarly marked as a Demo model on 3uTools. No clue as to the origin. It will occasionally notify that the battery is not original, despite this being untrue.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
There could be a number of reasons it is re-booting but if it does it around a set time it usually turns out to be a faulty charging port or battery. I would put the logic board into a known good housing to rule out parts but this is usually not an option for the everyday person so I would be looking at the battery and charge port assembly.
War diese Antwort hilfreich?
Bewertung 3
6 Kommentare:
Should this not have come alight when I turned it on completely unplugged, though? Otherwise you imply the absence of these parts immediately causes the mentioned problem on all phones.
von
@Smeargle The parts I mentioned talk to the logic board as Devin said the charge port on the X Series up have a sensor and the battery sends data to the phone that’s why a set time it re-boots would point to either of these parts.
von
I'll follow up after I give it a shot.
Better be the &&^&^$ case or I'll be dealing with a very serious loss...
von
Charge port done and did it.
Cheers.
von
Customer brought this issue into me with an xs max. After diagnosing, it turned out to be the power button flex. The power button still worked, but after disconnecting, and connecting a new one it began to work perfectly.
von
1 weiteren Kommentar anzeigen
Had this very same problem with an iPhone X immediately following a housing swap. I contacted STS Telecom (Which I totally recommend for data recovery) and the technician informed me that the iPhone X will restart by itself every 3 minutes if the charging port is not connected or it is broken. I went on eBay and ordered a high-quality replacement cable ($10-$15) and viola it was working good as new! I know this may not be the exact problem, but I hope this helps!
P.S From what I have heard, there is a temperature sensor on the cable and if the cable does not have that or it is damaged it will cause the phone to have a kernel panic and thus shutting the phone down. so make sure you have a good quality cable!
Bewertung 1
1 Kommentar:
I move the XS Max scarcely. Guess I'll have to take a gamble in ordering the part.
von
Antwort hinzufügen
Smeargle wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 51
Insgesamt: 2,809
