How can I remove a stripped screw from the logic board?
One of the 3.1mm screw heads is ruined and I can’t get the screw out. Any suggestions on how to get that out?
Ist dies eine gute Frage?
Hey…if you can get access, a good sharp pair of wire cutters with sharp points will grip the ruined centre and the side of the screw…but you got to squeeze.
War diese Antwort hilfreich?
use a 2mm drill carefully to remove most of the screw head, then use a 4mm drill to clean up. then pull the plastic case over wjha’s left of the screw. you can get the rest of the screw out with cutter or fine pliers.
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 63
