Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
4 Kommentare:
ok that could be due to a bad power supply or a bruned fuse (there is a fuse built into the wii i noticed) id try useing a multimeter and use the dc power mode and see if theres anything (im also not sure the voltage)
von keith s.b
Dl you have a multimeter?
von Andrew S
how bout we start easy dose the red light trun on? on the power button
von keith s.b
My doesn't charge neither does it turn on, so if you get the solution please tell me
von Encrypted
