Zum Hauptinhalt wechseln
Drahtloser Canon Pixma TS3122 Drucker
My printer head is stuck to the right and won't move
The printer head won't move I am trying to put ink and my printer but when I open it the header is stuck to the right I cannot manually move it and it keeps flashing error code p02 and then I turn it off and turn it back on and it changes to error code e04 is there anyway I can fix this on my own?
Ist dies eine gute Frage?
Bewertung 5
1 Kommentar
My printer cartridges are stuck to left
von
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
A few things to check.
1 Be sure nothing is blocking it’s path (eg all ink cartridge locks are fully in place)
2 Try unplugging the device and plugging it back in, sometimes the bootup sequence will move the carriage before the errors
3 Try running a test print, again that can sometimes work to start moving the carriage.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
My own is not moving it show error code p70 that's d code it show then orange light
von
I have turn it off for 10 minutes and turn it back still the cartridge head is not moving
von
As soon as I turn the printer on it goes into "unable to init.48 so the print head won't move. All functions have stopped. I checked all the wiring but can't find anything. How do i replace the print head if I can't move it to the left. Thankyou for any help.
Tom tomluikart@att.net
von
When I moved the print cartridges manually by gently pulling on the tape, I found a really gunky mess under where the black cartridge rested! Looks like the cartridge must have leaked and it was thick black gunk. Lots of cotton swabs, rubbing alcohol, and a new print cartridge and it all worked again! I also cleaned the metal rod that the cartridges slide on.
Bewertung 1
How to fix a printer head that is jam
Bewertung 1
your printer must be running. then open the front and lift the rest and it moved to the middle. the printer must be running. i just did it all.
Bewertung 0
Antwort hinzufügen
Nini Irene wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 19
Letzte 30 Tage: 54
Insgesamt: 17,759
