Zum Hauptinhalt wechseln
Apple kündigte am 9. März 2015 an, dass das Retina MacBook 2015, Modell A1534 am 10. April herauskäme. Es hat eine neue Unibody Konstruktion und beinhaltet ein verbessertes Trackpad, Tastatur und Retina Display.
281 Fragen Alle anzeigen
MacBook won't power on
I bought a used MacBook 12 inch(not sure what year) and it will not turn on. I tried the SMC stuff and holding down shift and the power button to no avail. The small lcd on the logic board by the battery disconnect turns on when plugged in, but when turned off it shuts off. I think the keyboard ribbon might need to be replaced not sure. Any help is appreciated!
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare:
Lets first nail down what you have here. Plug in the systems S/N here EveryMac - Lookup Let us know what it told you.
von
@danj Hi, it told me that it is the early 2015 version, not sure of any of the specs tho.
von
Einen Kommentar hinzufügen
1 Antwort
Problems with the trackpad or cables that route through the trackpad can cause power on issues. If you suspect any of these cables are damaged that could be a good place to start troubleshooting.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
@zpl The trackpad cable was cut as far as I know, but how would I go about troubleshooting them?
And is there a sensor anywhere, that shows that there has been water damage?
von
Antwort hinzufügen
BlackMassata wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 59
