MacBook Pro screen went blank/black suddenly
My laptop screen just went blank/black, but it still works fine if I connect it to my external monitor.
What’s seems to be the matter with my system?
Ist dies eine gute Frage?
I would suspect the display cable has failed. This is a known issue with the 2016-2019 USB-C model laptops commonly referred to as “Flexgate.” Apple has a service program that I would recommend taking advantage of if you can. The service program only officially covers one two 2016 models, but the same design defect is known to be present in the 2017 models. Here is the link to the service program. It may also be worth contacting an Apple Authorized Service Provider and talking to them about the issue.
War diese Antwort hilfreich?
Letzten 24 Stunden: 1
Letzten 7 Tage: 2
Letzten 30 Tage: 8
Insgesamt: 73
Use a flashlight pressed against the display at a sharp angle, do you see the faint image of your desktop and its icons?
If you do then the back light circuit has a problem. If you don't then the display assembly has failed.
von Dan
I will do that. Thanks
von Leana Golbert
@leanagolbert - What did the flashlight test tell you?
von Dan
