Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Model A1286. Veröffentlicht im Februar 2011 / 2,0, 2,2, oder 2,3 GHz Quad-Core Intel Core i7 Prozessor
650 Fragen Alle anzeigen
Screen Cracked and need to upgrade hard drive
I currently have a early 2011 Mac book Pro 15” that I havn’t used in 2 years since it won’t boot up. I was thinking about replacing the hard drive since I just had the same issue with my iMac and that works great now. What hard drive do people recommend? I also have a cracked screen and want to replace that also. Where can I find a good one because Ifixit is out of stock.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
This is a risky model to upgrade - the 15-inch 2011 MBPs have a known problem where the GPU tends to fail after so many years of use. It’s very possible that after replacing the hard drive and the display the GPU could go out, which would render the computer unusable. That being said, if you want to replace the hard drive I would recommend a Western Digital or Samsung SSD. Replacing the display is typically a bit more expensive and might not be worth the investment on an older model, but you can find options on eBay and other online retailers. You can also work around this by using an external monitor which may be cheaper to acquire. Hope this answer helps!
War diese Antwort hilfreich?
Bewertung 0
I like to use samsung for their ssd. you can check out ebay or amazon for the screen, get the oem screen is better.
Bewertung 0
Antwort hinzufügen
bchant888 wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 20
