Mac Air Not Charging After Battery Replacement
Spilled water on keyboard years ago. Decided to boot it up for S&G’s. It powered on, but quickly died. Changed battery (bought off Amazon). Plugged it up/Charging connector will not illuminate but computer runs flawlessly while plugged in. Ran apple hard check. Got error codes regarding charging adapter, and battery was not in good condition. Downloaded coconut battery. Should I replace the logicboard? (charging port is clean, usb drive works, as well as audio port). I’m at a loss? Details are as follows while plugged up.
Current Charge 3868mAH
Full Charge Capacity 7300mAH
Manufacture date 20201006
Cycle count 0
macOS Battery Status Good
Temp 85.4F
Discharging with 0 watts
Power adapter Connected.
Update (12/23/2020)
**Follow up regarding Error Codes. PPT007 - May be issue with adapter, or may not be connected. PPT002 - May be an issue with the power adapter, lists troubleshooting steps that all fail. PPT004 - Battery requires service. Not functioning normally.
Ist dies eine gute Frage?
Let's get a snapshot of CoconutBattery so we can see things Bilder zu einer vorhandenen Frage hinzufügen with the charger disconnected for a good 5 minutes and then plug in your charger and take a second snapshot again after a few minutes.
von Dan
