timing chain position on sprokets
I have a 2001 Pontiac Grand Am 2.4L 4 cyln. Where to set the timing chain if its out of place?
Ist dies eine gute Frage?
Here is a diagram the shows you how it is all setup. Just wondering if you have ever done this kind of work before. It is very involved and not quite as easy...
War diese Antwort hilfreich?
+ And if you get wrong you could destroy the engine. I usually change the water pump at the same time--you have to remove it to get to the timing chain. And double check the sprockets.
may I have that diagram too. thank you
@draccocain Carson, Dom, Below is the 2.4L 4 cyln. timing diagram. Good luck.
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 3,389
