Picture displays in 480p with safe mode, stuffs up in higher res
I have a PS4 that I am trying to fix. It was not displaying at first, but once I booted it into safe mode, the picture displayed. After restarting the console in 480p, I went into the settings to up the resolution, the display got worse the higher resolution I went, with red dots all over the screen(pictures below). The screen will slightly flicker on 720p and get worse at 1080i and 1080p.
My question is:
Has the HDMI port on the motherboard $@$* itself or has the HDMI chip on the motherboard done it in?
Thanks in advance!
Ist dies eine gute Frage?
5 Kommentare
Hi @rangsm8 ,
Did you verify that the problem is in the PS4 and not the HDMI cable or the TV (monitor etc) by trying different cables or a different TV etc?
von jayeff
@jayeff I tried 4 different cables, 3 monitors and a tv mate
von RangsM8
@rangsm8
Bit drastic maybe but try reinitialising the PS4 and then check.
if it is still no good then most probably it is the HDMI chip.
Save all your data first though
von jayeff
@jayeff
When you say to reinitialise is, do you mean to reset the console?
If it is the HDMI chip, would it be a case of just reseating it?
von RangsM8
[code]
Have you solved the problem?
I have exactly the same
[/code]
von Equipo Arroba
