Zum Hauptinhalt wechseln
7th Gen Amazon Fire HD Tablet was released June 2017. It has since been discontinued and replaced by the current Fire iteration.
液晶割れはどうしたらいいですか?
誤って、落下させてしまい、画面が割れ、タップしても全く反応しないのですが、どうすれば治りますか?ちなみに、電源ボタンはつきます。
Google Translate:
What should I do to crack the liquid crystal?
I accidentally dropped it, the screen cracked, and when I tapped it, it didn't respond at all. How can I fix it? By the way, the power button is attached.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
You can replace the whole display unit
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
どこでできますか?また、データは消えませんか?
von
Here is the link to a screen Amazon Fire HD 7 (7th Gen) Screen.
But i do not believe there is a guide on how to do it so I would just find a third party to do the repair. Just do not buy the screen unless you know how to fix it
von
@yutho No, the data WON'T disappear. The data is totally unrelated towards the screen. All of your data is in the motherboard. Once your motherboard breaks or gets damaged, then that is the time at which your data may or will be lost. How is the condition with the cover of the device? That may also be in need of replacement if it is also damaged badly from that drop. Hopefully, your device was repaired after 5 years.
von
Antwort hinzufügen
吉家 問うう wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 31
Insgesamt: 612
