Zum Hauptinhalt wechseln
Reparaturanleitungen für das MacBook Air, Apples aktuelle Serie für Consumer-Laptops.
4514 Fragen Alle anzeigen
Airport/Bluetooth-Karte wird nicht erkannt und Treiber nicht geladen
MacBook Air A1304 , Karte und Flachbandkabel wurden ersetzt, aber keine Änderung. Bluetooth funktioniert, aber WLAN nicht. Vorher wurde der Akku erneuert, weil tot.
Update (16.01.2021)
Problem not solved…
At the m-Store i was before, they told me my logic board is dead and needed to be replaced… and because of the MacBook Air was out of support, the don’t help me. After several Month the Accu was at Zero, and suddenly the Macbook booted again with power supply and come to life. I renewed the Accu and now I try to solve the next Problem. Wifi … ( WLAN ) is dead but Bluetooth works first… Maybe the Powersupply from Logicboard to Airportcard is broken.
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare:
Nachtrag: Beim Austausch der Karte ist mir noch aufgefallen, das die Karte nicht mit einer Schraube fixiert ist, sondern nur durch die schwarze Abdeckung gehalten wird. Laut Anleitung sollte oben rechts in der Ecke eine schwarze Schraube 3,2mm Kreuzschlitz sein.
von
At the m-Store i was before, they told me my logic board is dead and needed to be replaced ... and because of the MacBook Air was out of support, the don't help me. After several months the Accu was at Zero, and suddenly the Macbook booted again with power supply and come to life. I renewed the Accu and now I try to solve the next problem. Wifi… (WLAN) is dead but Bluetooth works first… Maybe the power supply from Logicboard to Airportcard is broken. https://19216811.cam/
issue got solved!!
von
Einen Kommentar hinzufügen
1 Antwort
I took it to the Apple Store and they had a look and said the Airport card needed to be replaced. I replaced it but still has the same problem; does not work.
Wifi though worked just fine before and after the replacement
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Martin Carstensen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 52
