Zum Hauptinhalt wechseln
Das im November 2020 erschienene 13" MacBook Air verfügt über Apples Arm-basierten M1-SoC mit einer 8-Kern-CPU und bis zu einer 8-Kern-GPU. (Modell A2337 / EMC 3598 mit zwei Thunderbolt 3-Anschlüssen)
174 Fragen Alle anzeigen
Any suggestions for making this dent disappear?
Hey everyone!
Unfortunately, I’ve managed to drop my macbook and now there is a dent on the back of the screen. The display is fully functioning, it just really hurts every time I look at it. Do you have any idea how to fix this without changing the whole display? I don’t want to do it DIY but is there any chance it can be fixed like car dents?
Pic:
I’ve worked really hard to finally buy it and now I feel terrible, I’m looking for a “budget-friendly” solution, but every answer is appreciated.
Thank you in advance
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
The problem with aluminum dents is they’re just there forever, especially on Retina models with how the assembly is built :(. Even when you can fix it, it’s still going to always be there.
You can sometimes remove the LCD from a non-Retina to improve the situation (albeit with some difficulty) but not on these - the bare LCD is bonded to the glass and the layers are in the aluminum shell.
Sad to say you’re buying a display or living with it.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thank you for the quick answer!
von
As a low budget solution you can get an external case/cover or a sticker to cover it up! Check here for ideas.
Bewertung 2
1 Kommentar:
Smart idea! I've seen people with stickers on the back of their laptops so it won't look weird.
von
you can try with a bubble car puller!
Bewertung 0
Antwort hinzufügen
Peter Tarr wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 61
Letzte 30 Tage: 256
Insgesamt: 4,661
