Mac won't boot / Only 1diagnostic LED
Well, another case of boot failure with only the first LED (501) lit.
Actually, I’ve already tried everything that’s been recommended here.
On pin 4, 11 and 12 I measure 11,93 / 11,94 V.
Could this slightly lower voltage be the reason for the Mac failing to boot?
Ist dies eine gute Frage?
1 Kommentar
The case for whether a voltage is good or bad is based in tolerance. Most power circuits have anywhere from 5 to 10% tolerance, but this can vary by spec. If the reading is within the +/- % tolerance, then the voltage is good.
von Isaac
