Zum Hauptinhalt wechseln
Hochleistungstablet von Apple herausgekommen am 11. November 2015. Model A1584.
122 Fragen Alle anzeigen
Battery won't charge after display replacement
I successfully completed this guide but when I put everything back together and turn it on, I only see the low battery indicator (even when plugged in) I left it plugged in for several hours but I only ever see low battery. Occasionally the screen will light up with the Apple logo and show the keypad. It even registers a couple of key presses but before I can enter the passcode the iPad turns off. What is going on here?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Double check if the battery connector is properly seated. I recently noticed something similar with an iPhone where the connector wasn’t 100%, but just enough for it to power on, but not to be properly detected in order for it charge.
War diese Antwort hilfreich?
Bewertung 0
Kommentare:
I took it to a repair shop and they confirmed it was in a boot loop. it's such a common problem with my particular model of iPad they refuse to fix them. I've since given up on it.
von
Antwort hinzufügen
Brandon der Blatter wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 11
