Keyboard replacement Acer cloudbook
Hello, the keyboard of my Acer aspire cloudbook 11 is malfunctioning.
Is the replacement a easy task? Ir it is not worthy ?
Thanks
Ist dies eine gute Frage?
Thanks
This really depends on your location, abilities and the replacement part availability. If this netbook works for you, consider replacing the keyboard rather than filling a landfill with e-waste. It looks like the parts are available, but you would have to remove all the components before being able to get to the keyboard.
If you do attempt this, my recommendation is take a photo of everything BEFORE you disconnect it so that you can reference it back when you reassemble.
Also it looks like the replacement keyboards come with the full top plate as it’s probably riveted or perma-installed with it.:
https://www.laptopkeyboard.com/keyboards... (this is a quick example and I do not condone or suggest you purchase this unit from this vendor, it’s just the first one I googled for illustration purposes).
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 68
