Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Apples 2016 Überarbeitung, ihres auf professionelle Benutzer ausgelegten Laptop Lineups. Es ist ausgestattet mit einem 15 Zoll 2880 x1800 Retina Display, einem quad-core Intel Core i7, mit 256GB / 512GB / 1TB / 2TB Speicherplatzoptionen, 16 GB RAM Arbeitsspeicher und einer Tastatur mit einer Touch Bar. Es erschien im November 2016. Modell: A1707.
204 Fragen Alle anzeigen
Boots to flashing question mark, but boots OK to external drive
This A1707 cannot access internal SSD, but runs fine on the external drive. I tried Disc utility via recovery and via external drive. Internal is recognized, but cannot be altered in any way, not erased, nor new OS installed, nor first aid. I checked for water damage, nothing to see. I checked the “life boat” , but nada. Running out of options, the SSD is fixed on the board…Any thoughts…I saw videos discussing the 1706 which has a “usual failure” in the 2v7Nand circuit, but cannot correlate it to the 1707…
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Is the internal drive recognized when booted into an external drive? If so, can you erase and reformat in Disk Utility from that external drive? If not, what sort of error does Disk Utility give? Apple had a known issue with their SSDs on the 13-inch models, I wonder if this is something similar - it’s not unprecedented for them to limit their service programs to only a small selection of machines effected by the issue. If you aren’t able to erase and reformat the drive from either a bootable external drive or from internet recovery mode you may need to contact an Apple Authorized Service Provider.
War diese Antwort hilfreich?
Bewertung 0
Kommentare:
It does recognize the internal drive when booted of an external. But I can neither mount the partitions nor first aid them, nor delete them, nor restore them. I tried a number of times but no go. There is no liquid damage on the board, I took it out today and looked at it under the scope, it is clean on both sides. It is a 15"A1707, so the Apple recall does not affect this. I suspect that the SSD is just corrupted and now I am stuck with it, because it is soldered to the LB...
von
Antwort hinzufügen
Jurgen wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 13
