01 - Drain Pump
The drain pump uses an impeller to force water through the drain hose. If the drain pump motor is not working, the dishwasher won’t drain. To determine if the drain pump is defective, check the pump motor for continuity using a multimeter. If the motor does not have continuity, or if is getting power but won’t run, replace the drain pump. Drain pumps are not repairable—if the drain pump is defective, you must replace it.
02 - Pump and Motor Assembly
The motor drives an impeller to force water out of the drain hose. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
03 - Clogged or Improperly Installed Garbage Disposer
If the garbage disposer was installed recently, the drain plug may not have been removed. All garbage disposers are sold with a solid plug in the drain tube. If the dishwasher is not connected to the garbage disposer, the plug must remain in the drain tube. However, if the dishwasher is connected to the garbage disposer, the plug must be removed. If the garbage disposer wasn't replaced recently, it is possible that the disposer is clogged. Remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
04 - Drain Hose
The drain hose might be clogged. To unclog the drain hose, remove the drain hose from both the dishwasher and the sink drain and clean it out. The drain hose is most commonly clogged near the garbage disposer or dishwasher drain branch tailpiece.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
2
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
3 Kommentare
I have the same problem when it’s hot it will not
Drain
Have run diagnostics by entering any three buttons quickly three times in a row
Dishwasher passes
just wanted add don’t hear the pump coming on when it’s hot and I hit the cancel button, I’ve tried holding it in. That doesn’t help either. This has not been fixed. no solution yet
i’m going to experiment with different settings. I usually run with hot water setting, but not heated dry. Going to run it without hot water setting will let you know it’ll take a few days.
11 minutes ago by pingme
von pingme
Pingme, I have already posted previously that these dishwashers use a pump that CANNOT handle consistent use of the "sanatize" and/or extended heating options. When sanatizing, the water is so hot the pump stops working or degrades after each use until it is bad. After it cools down, it will work again but the damage is done. Get a replacement pump, replace it and stop using "sanatize" or extended heating and it will work. It has for me since I replaced my pump. When the cycle ends, pull out your trays and make sure there is no "standing water" on any dish (turn them over). They will finish drying quickly since the dishes are still very hot. Good luck.
von Rob H
So what happened? How was it fixed?
von Danny Caspi
