Zum Hauptinhalt wechseln
Aktualisierte Version des Retina MacBook 2016. Modell A1534, EMC 3099. Jetzt mit schnelleren Kaby Lake Prozessoren bis zu 1,4 GHz Core i7 mit Turbo Boost bis zu 3,6 GHz und bis zu 50 Prozent schnellerer SSD und unterstützt bis zu doppelt so viel Speicher.
81 Fragen Alle anzeigen
I used my computer last night, now it won’t turn on or charge up.
I just used my macbook last night to do homework then watch youtube. I left it plugged up when I went to bed. This evening it won’t turn on or charge up. I’m not sure what is wrong with it.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Here are some things you can try: 1) With the charger plugged in, press and hold the power button for about 10 seconds. Then press the power button again. If the machine still does not power on, move onto the next step 2) Attempt to reset the SMC. After resetting the SMC, attempt to power on. If you still aren’t able to power on, move onto the next step 3) Try using a separate known-good charger. If you don’t have access to a charger you can take it to a tech shop and ask them if they can try to charge it as a free service. If it charges using a separate charger there may be an issue with your charger and it might need to be replaced. If none of these steps work for you there may be a hardware issue with your machine. If that’s the case I would recommend having it diagnosed by a Mac repair shop. If you’re feeling adventurous you can try disconnecting and reconnecting the battery, but be forewarned that these models can be a little tricky to open safely. Here’s a guide for accessing the battery.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Lexie Savannah wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 35
