Zum Hauptinhalt wechseln
Das ist die Variante ausschließlich mit Wi-Fi der fünften Generation des iPad, erschienen im März 2017. Erhältlich mit 32 und 128 GB Speicher, einem 9,7" Retina Display und einem 64 Bit A9 Prozessor.
iPad Home Button not working after Digitizer Replacement
I replaced the digitizer specifically because I accidentally broke the home button connector ribbon. I have to use the one I have (the new one I mean) or buy another. When I connect the digitizer and LCD panel, the home button does not work. I have not fully assembled the iPad yet, as I wanted to check if it worked. Do I have to fully assemble to get the button to work? and if not then can anyone see my problem?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
That looks like an iPad Air home button, which carries a different protocol and is not compatible with iPad 5.
Either that or the home button is faulty.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
That’s actually a really helpful input, when I bought it it was labeled as a digitizer for iPad 5 or iPad Air. So does this mean that it just really isn’t the right home button?
von
@Nathan Mayo That explains it, you got the wrong home button (iPad Air)
von
Antwort hinzufügen
Nathan Mayo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 108
