Zum Hauptinhalt wechseln
Die Neuauflage des Apple 13" MacBook Air von April 2014 wurde mit Dual-Core i5 und i7 Prozessoren aufgefrischt. Die Akkulaufzeit wurde etwas verbessert.
313 Fragen Alle anzeigen
Apple MacBook Air a1466 battery won't charge and sound not working
Hello Guys
After finish installing a new screen install in my MacBook Air A1466 The screen works perfectly .
The issue I have now, is there is no sound (sound bar is greyed out)
And also the battery will not charge (no light on the MagSafe charger, )
The MacBook will turn on when I use the MagSafe charger though but the battery will not charge
I did not check if any of these worked before I installed this new screen on this old laptop.
I have reset the SMC and PRAM to no avail . I have plugged in and plugged out everything that I had to when installing the new screen.
I have tried 3 different chargers in a combination of different ways and the light will not come.
I am a bit stumped.
I have attached images of the inside of the system as well as some system information.
If any one could help that would be great .
updated post
images of I/O connecter cable
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare:
Flip the I/O board cable over and take a set of pics each connector and post them here so we can see them.
von
@danj
I/O board cable images added
von
Nothing visible, I would still swap out the cable first, if that failed then its the I/O board.
von
Einen Kommentar hinzufügen
1 Antwort
I suspect your I/O cable is bad MacBook Air 13" (Mid 2013-2017) I/O Board Cable
MacBook Air 13" (Mid 2013-2017) I/O Board Cable Bild
Produkt
$14.99
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Stefano Molle wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 242
