Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Das März 2015 Update von Apples 13" MacBook Pro Retina Display, Modell A1502, bietet fifth-generation Intel Core i5 und i7 Prozessoren der 5. Generation und führt den Force Touch Trackpad ein.
981 Fragen Alle anzeigen
Why I have thick vertical bar suddenly appear on my display?
Suddenly out of know where I have a thick dark vertical bar showing on my retina display. Anybody else have this kind of problem?
And sometimes inside the bar, it retains a few of my previous images (like LCD shadow/ghosting)
But in the middle of the bar every image I put in there, left a ghosting/shadowing mark on it, it was like this in video: MacBook Pro Retina Early 2015 display has blur horizontal thick line & shadowing problem
Any fix for it? Except changing the whole display assembly of course.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Try disconnecting the display cable, inspecting the pins both on the cable side and the port side for damage, dusting them with compressed air, then carefully reseat the cable. If that doesn’t help, you can try replacing the cable itself (cheaper than replacing the display). In my experience though, this specific visual glitch is normally due to damage to the display assembly itself and not an issue with the display cable. It may also be worth checking with an external monitor to verify the issue is not with the graphics, but rather the hardware of the display. My best guess is that the display assembly itself is damaged and would need to be replaced.
War diese Antwort hilfreich?
Bewertung 1
Kommentare:
Yes its a T-CON issue within the display ;-{
von
bad luck ? i just bought this from a friend and use it for about 3 days, changing the whole display assembly would cost as much as the macbook itself
von
Antwort hinzufügen
Aaron wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 28
