Zum Hauptinhalt wechseln
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
318 Fragen Alle anzeigen
Dryer won't start-No F01 Code
The Dryer does not have power going to it. Checked outlet, it has power so itisn’t a power outlet issue. Fuses are all in good shape. Repairman suggested control panel issue, but couldn’t replace due to his company not carrying the panels.
In all other cases for this dryer, I have seen changing the control panel as a solution to the F01 error code, not for a dryer that won’t start, period. Does this seem like a solution, or does this seem like the dryer is just done. I just don’t want to pay 150 for a control panel if it likely won’t do the trick!
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Hi,
What is the model number of the dryer?
von
Einen Kommentar hinzufügen
1 Antwort
If you have had a power outage or surge recently this is most likely the answer to the problem.
If this is the case the answer is to buy the new control panel.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Jillian Pastick wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 829
