Zum Hauptinhalt wechseln
A2115 / 2020 / Prozessoren beginnend mit 3,1 GHz 6-Core i5, bis 3,8 GHz 8-Core i7. Markteintritt am 4. August 2020.
31 Fragen Alle anzeigen
Will it boot with only one 8G stick of ram?
Will this iMac boot with only one stick, or does it REQUIRE a pair? Also, does it/they have to be installed in any particular slot? This iMac won't turn on at all. I got it with NO ram at all because the previous owner used it all in his new iMac.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
If we review this Apple T/N Install memory in an iMac
We’ll find this statement “If you have mixed capacity DIMMs, see the install memory section for installation recommendations.” And we jump down to that section: “iMac (Retina 5K, 27-inch, 2020) DIMMs have a notch on the bottom, slightly left of the middle. If your DIMMs are mixed in capacity, minimize the capacity difference between Channel A (slots 1 and 2) and Channel B (slots 3 and 4) when possible.
So you really can’t mix within the channel only across channels. So you’ll need to install your different RAM sizes in Slot 1 and Slot 3. Don’t forget to allow the system to initialize which can take awhile!
Given the cost and the performance benefit I would just go with a matched pair within each channel pair.
War diese Antwort hilfreich?
Bewertung 1
7 Kommentare:
Hi Dan. Thanks for the response. I will edit my question to be more specific.
This iMac won't turn on at all. No fan, no display, nothing. I got it with NO ram at all because the previous owner used it all in his new iMac. Can this particular iMac boot with only one stick, or does it REQUIRE a pair?
von
@rippegari - What is the size of the SO-DIMM's you are trying to use?
von
@rippegari - Well... you didn't really answer the question.
So being a single SO-DIMM I'm guessing its the 8 GB unit. Put it into Slot 1, turn your system on and go get a cup of coffee and some breakfast. When you get back your system should be booted up (it does take a good amount of time for it to initialize)
But if the RAM was pulled is the drive still present or just wiped? You maybe greeted with a blinking question mark in a folder.
Frankly, I always install two SO-DIMM's.
von
Apologies! Yes, it is one 8GB unit. I'll give it another go. Thanks,
von
2 weitere Kommentare anzeigen
Antwort hinzufügen
James wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 5
Letzten 30 Tage: 12
Insgesamt: 389
