Zum Hauptinhalt wechseln
Repair guides and support for the laptop line of Acer's Aspire series for casual home and business use.
1192 Fragen Alle anzeigen
Laptop's LCD works, but not when its plugged into an external monitor?
The laptop’s LCD screen is working but, when an external monitor is plugged into it, it’s only showing on the external monitor. When trying to change the settings to extend the screen, it’s still only showing on the monitor and will revert to “Show Only on 2” in the display settings.
It started, but I managed to find a workaround where I turned the laptop on and then plugged the monitor in, and that was working fine for about a week or so but is no longer working.
What do I do to fix this?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
so does it still swap to the external monitor still work when plugged in?
von
Einen Kommentar hinzufügen
1 Antwort
Select dual display in your display device option. Then try plug in another moniter.
Did you connect to the external monitor with a VGA cable? VGA sometimes overrides the main monitor.
If your computer has just a VGA output you'll need a VGA-to-HDMI converter. Try to connect with a HDMI cvable and see if the issue persists.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
No, I've connected with a HDMI, sorry, I should have mentioned that.
von
@spiritofwrath This seems like a display driver issue, hence I'd recommend you to download and install the most recent display drivers from the manufacturer's website.
If updating drivers not works. Try to uninstall and reinstall display drivers in compatibility mode and check if it helps.
von
Antwort hinzufügen
SpiritOfWrath wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 31
