Zum Hauptinhalt wechseln
Reparatur- und Zerlegeanleitungen für das Pixel 4 Smartphone von Google, herausgekommen im Oktober 2019.
44 Fragen Alle anzeigen
My pixel 4 wifi will not connect unless I'm close to the router
Hello
I changed the screen with the body to my pixel 4 because the original screen broke. After I fixed that the phone won't connect to wifi. I noticed the the coaxial cable on the phone was damaged so I bought galaxy s8 cable from ifixit, because they didn't have pixel 4 cable. I replaced it but the problem remained the same. I did all the troubleshooting steps online and still didn't fix the problem. Any suggestions to how I can fix the issue?
Thank you
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi,
Check that the WiFi antenna cable is securely connected at both ends.
Here’s the iFixit Google Pixel 4 Hauptplatine tauschen guide that may help you.
One end of the antenna cable is shown in Step.34 of the guide
It can be seen in the image with this answer. It is the grey (white?) cable with the silver connector just below the orange flex cable at the bottom and it goes up past the left side of the battery
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thank you! I replaced battery and I may have dislodged that connector by the battery. I'll have to look at it one more time to see if that's the case.
von
Antwort hinzufügen
Ayad King wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 328
