Zum Hauptinhalt wechseln
A2115 / 2020 / Prozessoren beginnend mit 3,1 GHz 6-Core i5, bis 3,8 GHz 8-Core i7. Markteintritt am 4. August 2020.
44 Fragen Alle anzeigen
Can be this model 2020 be upgraded to i9?
Model Name: iMac
  • Model Identifier: iMac20,1
  • Processor Name: 8-Core Intel Core i7
  • Processor Speed: 3,8 GHz
  • Number of Processors: 1
  • Total Number of Cores: 8
  • L2 Cache (per Core): 256 KB
  • L3 Cache: 16 MB
Ist dies eine gute Frage?
Bewertung 5
27 Kommentare
Here's your systems series: iMac20,1
these are the possible CPU's your system can support.
von
Is possible upgrade with I9 10900KF??
thanks
von
The 3.6 GHz Core i9 (I9-10910) is the best CPU Apple used in this series.
Core i9-10910 Processor
Core i9-10900KF Processor
As you can see you loose the UHD Graphics 630 which Apple uses at startup, and you wont get the higher clocking. Best to stick with what Apple used.
von
Hi Dan
So you confirm that I can install the 10900KF? By not having integrated graphics it will heat up less.
Thanks
von
@eullin - Cutting off your right leg will use less blood, but you can't run very well. This is the same issue as you'll loose the startup services without the IG services.
I personally wouldn't do it. Heat is really not an issue if you use a good thermal monitoring app like TG Pro.
I would also make sure the vents are not blocked and clean out the dust yearly.
von
22 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
So while it’s possible its not an easy process!
We don’t have a guide for your exact system but this one is very close to the same procedure to get the logic board out iMac Intel 27" Retina 5K Display Logic Board austauschen Keep in mind you need to use the correct tools and technique to get the display off otherwise you risk damaging it!
After taking the logic board out getting the current CPU out is not that hard but putting the new one in as a real pain! Many people struggle getting the CPU properly placed in the socket and/or damage the logic board socket in the process.
Of the three systems I got in which someone had attempted to install a replacement CPU in this design series two had damaged to logic board to the point I couldn’t save it.
Also be careful on what TIM you use and don’t over do it! It takes very little to do the job.
War diese Antwort hilfreich?
Bewertung 3
3 Kommentare:
wow that is a lot of work, seems like you would be better off just replacing with a mobo that can handle it.
von
@spacecadet420 - Sure replacing the logic board with the i9 installed already also works.
von
What is the best i9 chip ican upgrade for imac 5k 27” 2019 ( 3ghz 6core intel i5?
von
I upgrade mine to the i9 10850K everything's appears to be working fine.
I'm worried that the power supply won’t last for a long time.
Bewertung 1
6 Kommentare:
Your lucky! Both have the same TDP and are based on the same microcode (Comet Lake).
Intel i9-10910 CPU
Intel Core i9-10850K
von
macOS Monterey no issues with the upgradet iMac so far (10850K)
von
10850K not work, i was try this. iMac 2020 and 3.3Ghz i5 - 10600. When I replaced it, only 2 LEDs were on instead of 5. This indicates that the graphics did not start at all
von
@rsxkct3wpy40hp1 - are you sure you mounted the chip properly? These are hard to seat into the socket and if you’re no careful you can damage the chip as well as the socket.
Be aware unless you have the needed cable extensions you can’t test the system by the onboard diagnostic LEDs. Often the pulling on the cables damages the logic boards data cable connector and/or the cable it’s self.
I know of a few people who have swapped out the chip so it can be done.
von
may I know what your imac's Model Identifier is? iMac20,1, or iMac20,2? cheers.
von
1 weiteren Kommentar anzeigen
Antwort hinzufügen
djleba wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 36
Letzte 30 Tage: 112
Insgesamt: 6,178
