Can be this model 2020 be upgraded to i9?
Model Name: iMac
- Model Identifier: iMac20,1
- Processor Name: 8-Core Intel Core i7
- Processor Speed: 3,8 GHz
- Number of Processors: 1
- Total Number of Cores: 8
- L2 Cache (per Core): 256 KB
- L3 Cache: 16 MB
Ist dies eine gute Frage?
27 Kommentare
Here's your systems series: iMac20,1
these are the possible CPU's your system can support.
von Dan
Is possible upgrade with I9 10900KF??
thanks
von Eugenio
The 3.6 GHz Core i9 (I9-10910) is the best CPU Apple used in this series.
∙ Core i9-10910 Processor
∙ Core i9-10900KF Processor
As you can see you loose the UHD Graphics 630 which Apple uses at startup, and you wont get the higher clocking. Best to stick with what Apple used.
von Dan
Hi Dan
So you confirm that I can install the 10900KF? By not having integrated graphics it will heat up less.
Thanks
von Eugenio
@eullin - Cutting off your right leg will use less blood, but you can't run very well. This is the same issue as you'll loose the startup services without the IG services.
I personally wouldn't do it. Heat is really not an issue if you use a good thermal monitoring app like TG Pro.
I would also make sure the vents are not blocked and clean out the dust yearly.
von Dan
22 weitere Kommentare anzeigen
