Zum Hauptinhalt wechseln
Veröffentlicht am 21. September 2018. Modelle A1920, A2097, A2098, A2100. Erhältlich als GSM oder CDMA / eSIM oder dual-SIM / 64, 256 oder 512 GB / Silber, Gold oder Space Grau (Ausgesprochen "iPhone 10s.")
221 Fragen Alle anzeigen
Screen will not wake after replacement.
I have just replaced the screen on a friends iphone xs. I removed battery first and followed the guide to the letter. When i first turn on the phone the screen comes on, i put in passcode and can use apps, surf the net everything. As soon as i lock the screen or it locks itself, then it will not turn back on. The phone still works as i can feel it vibrate and can soft reset it. After soft reset, the screen works again, until locked. Anyone else had this problem?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hi, put the old screen back and see if problem is go away. So you know if it is a faulty screen you received or it is a other problem.
War diese Antwort hilfreich?
Bewertung 0
Kommentare:
Hello. Yes i tried the old screen and that works fine, as it should. Never seen this problem before. Screen come on after boot and soft reset but just will not wake off button, tap or lifting the phone. I thought it must be the screen, just know there are so many issues when changing parts on apples. Many thanks Leslie
von
Antwort hinzufügen
Trevor Webb wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 11
