Zum Hauptinhalt wechseln
The Smart Oven® with Element IQ® is a trustworthy tool for the cook who wants a countertop oven that roasts succulent meat, broils, bake pizza, reheas leftovers and toasts evenly. Convection setting reduces cooking time by up to 30%. Model: BOV800XL
Convection fan hums but doesn't turn.
The convection fan isn’t turning when trying to use the convection setting on the Breville toaster oven. Motor hums (60 Hz I believe) when trying to turn. Everything else works fine. Heating elements, display, etc.
Convection fan turns freely by blowing pressurized air across blades with power off or convection setting off. The fan will continue to spin for 30 seconds or more.
If the fan is spun initially and the convection function is then turned on, the fan quickly slows and stops.
Ist dies eine gute Frage?
Bewertung 6
11 Kommentare
Have you ohmed it out? Check the motor for specs and check amp draw. Might have bad windings on it.
von
Will do, if I can get to the motor. From what I've seen on the web, these things are a bear to take apart. Apparently, a really long screwdriver is needed to reach from the back to the front at some point.
von
Opened it up and was able to get to the motor. Resistance was 150 ohms. Looked for specs (SDR5812-01A15 120V 60Hz 15W). Only thing I was able to find was that this part is no longer available on a couple of repair websites.
Turned motor several times by hand, no real resistance. Noticed some play (~1mm or maybe less) where shaft can go in and out. Pushed and pulled along axis and turned motor. Noticed some minor scraping from the fan blades inside the oven (couldn't see these). Assumed it may be crud and did it a few more times and the scraping decreased.
Put motor straight to 120V 60Hz. Motor turned no problem. Put everything back together and now it works.
Motor does make a low, dull knocking sound when turning (not tinny like the fan blades are hitting something). Don't really know if it was doing this before.
I suspect the bushings are going bad and the "fix" is only temporary. Guess I'll start saving up for another one.
von
@cbhuffman very odd... normally bearings go (screeching/grinding/whining sounds) or fan is hitting something... sounds you described is very 9dd indeed. And yeah I can't source a motor n either. And it is such a strange looking motor i can't think of one that could be used in its place.
von
My son bought us this one in 2019 - fan died in just over a two years. The Delonghi I threw away was still working after over 15 years. Oh well.
von
6 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
14 Antworten
Hilfreichste Antwort
Hi @cbhuffman,
For what it’s worth the fan motor part number is Breville part # SP0010500.
I’ve searched online without success as all suppliers state that it is no longer available from the manufacturer. You may have better luck.
There is always trying the donor parts option perhaps, i,e, search online for a faulty oven but having a different problem, if you consider it’s worth taking the risk on the fan working OK and the price suits. Just a thought
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
This is a shaded pole motor , if it will turn if you help it it needs oil,the bearings have packing around them that holds oil, soak them with zoom oil. These motors dont usually burn out if they get stuck like other motors.
von
How do I access that fan motor?
von
Total pain in the butt... i ordered a jy58 motor.. 220v unit.. and will attempt to merge the 2 motors together to make 1 working unit. The 'clips' are not able to be attached.. so im going to transplant them from a 220v motor to the original 110v windings. https://www.amazon.com/dp/B0987TMX53
and the verdict is... yes, it can be done... and yes, the frankenstein motor works.. with a few notes:
.25) Be EXTREMELY careful. the covers are razor sharp.
.4) Have a torch handy. The screws on the sides of the fan blade hub are frozen solid, torch the hub for 15 seconds to loosen the Allen screw.
.5) take pictures as you disassemble the unit. Better yet, wait to disassemble until donor motor arrives. 1-2 weeks introduces a lot of mistakes when reassembling
.75) The screws holding the endcaps on... wet with acetone before trying to take apart.. otherwise, they will NOT come apart. they used some type of Lock-Tite in the threads that makes it a PITA if you don't soak with solvent.
1) The endcaps/bushing mounts don't fit. you need to (I used a stair step drill-bit) drill to open the magnetic winding core so the endcap alignment protrusion fits, after a minor drilling, they clicked right into place. Stair-step bit will auto center.
2) The center core needs to be swapped between units. The above motor doesn't have the external fan shaft for cooling the control board
3) the core doesn't match the same size. using the spare washers from the donor core, you can space them correctly. If you are still front to rear sloppy on the shaft, ace hardware carries nylon washers that fit. I bought 4 washers, I think I only used 1.. maybe 2. (23 cents apiece)
4) Be slow at disassembly and careful handling the motor core.. my unit is like 8? years old and the insulating plastic is brittle as all heck..
Did I mention to take pictures.. take A LOT of them....
reassembling the endcaps with the original core, don't use the new core's screws.. the motor wont fit if you try. The screws are too long.
The endcaps are NOT universal. Place the endcap with the threaded screw holes on the long shaft side of the motor.
Don't be afraid of sharpie marking panels as you disassemble.
Don't miss-place the spacer washers between the metal plate, insulating pad, insulating plate, and motor (take a lot of pictures)
If you need to step away and scream.. do so.
when the wife says "is it on? It isn't making that grumbling/buzzing noise anymore", smile.
Note: the original motor had a defective design. The new motor endcaps are crimped to not fail in the same way.
Note: if when re-assembling, the cover wont fit (right side).... the fan blades face INWARD.... /facepalm
Bewertung 2
2 Kommentare:
I can verify this method works. Disassembling the oven is a PITA, but at least they didn't glue it together.
von
I agree: the design is poor. It's unbeliable how many screws they used to asseble the oven !
von
Same here. This is my second, and there will be no third for me. It's time to move on. There are better companies out there.
Bewertung 1
1 Kommentar:
Ditto on that. No more Brevilles !
von
The lubricant dried and the motor shaft seized in its bushings. I took it apart, cleaned and re-lubricated. Lasted another 2 years.
Bewertung 1
1 Kommentar:
I tried that. Even used teflon based light oil. Lasted about 6 months - it's a design issue that makes lots of moola for Breville. Trying out a totally different toaster make after seeing this issue on a new Breville unit after just 3 months !
von
Mine was not ceased, but had excessive play -worn bushings. I managed to locate a spare motor, although with slightly different shaft end, but still managed to fit and and it still works already two years
Bewertung 1
1 Kommentar:
Where and what motor were you able to find? Part number? I wouldnt mind giving it a shot as well! Thank you!
von
the YJ58 is an oven fan rated at 220/110v with the exact same specs! you are welcome people!!!
LONG LIVE THE 800XL!!!
Bewertung 0
4 Kommentare:
Has anyone tested the YJ58 as a replacement part? Our 800XL just did the fan death harry carry...
von
There are 4 different versions of the YJ58.
Can anyone confirm the exact model number?
von
@peterd95081 check my posting on the repair.
von
YJ58-12 or YJ5812 15 watts 120v 60hz
von
From your efforts, it sounds like the fan was hanging up on that "crud". Just do a good cleaning to totally eliminate that "dull knocking sound". The fan runs fine outside the unit - so it has to be interference making the noise.
Update (12/24/2022)
That fan doesn't have a starter capacitor on it, does it?
Bewertung 0
1 Kommentar:
No it is a shaded pole motor.
von
I had the same problem. I completely removed the motor and took out the 2 screws holding the motor together. I found that the bushings were not worn at all, but the oven side bushing was loose. There's ring "clip" holding the busing in place. The clip looks like an inside out flower (pedals facing inward instead of outward). I applied some pressure on opposing pedals with a pair of needle nose pliers to reseat the busing and tighten it up. That removed all play in the shaft. After reassembling everything the noise was gone and the motor no longer stalled.
Bewertung 0
2 Kommentare:
can you show a photo of where the 2 screws are? i took off the cover, i see the fan from the outside, but i don't see any access to the fan facing the inside. i do notice that something that was holding it up was loose but not sure where that holder is at
von
von
After about 3 years of use, the fan in our oven started making noise.
I had success with lubricating the fan through the inside vent... without taking the oven apart!
Place the oven on its right side. With the door open, the fan and vent will now allow a silicon spray (with a 'straw' attachment) to be directed through the vent to the center hub without dripping too much. After leaving it set for a few minutes, I plugged the oven in and turned on a cook setting that used convection and there was absolutely no noise.
This may change over time if the silicone dries, thickness or coagulates but... I will try another 1 minute fix before attempting to disassemble the metal housing.
Bewertung 0
1 Kommentar:
Ditto for me. However the lubricant only works a few months (depending on use) and the problem is back. The best solution is anotjher brand as I've gone through 2 units in the past 6 years with the same issue including a NEW unit only 2 weeks old.
von
Mine was making a loud hum as described. I took it apart and then reconnected the to control board connections and plugged it back in with the housing off so I could make a guess as to where the failure was, and it just started working again.
Costs nothing, worth a shot.
My best guess is that there was a bad connection somewhere that I re-seated.
The part I had the most trouble with was getting the housing off. There's a folded pinch connector at the front just where the housing meets the top of the hinged door, and you have to pull the housing straight back to get it off. It was really stuck there.
Before I did that I took off the feet, all of the screws on the back, and one screw under the bottom of the control panel accessible through a small hole.
Bewertung 0
The shaded pole motor has bronze bearings that wear out, when they wear it allows the magnetic field that drives the motor to pull the stator against the armature. Since the magnetism is able to pull the part that is supposed to turn against the part making the magnetic field that makes it turn they stick together when electricity is applied. The hum means the motor is not turning. The only option is replacing the motor, or making new bearings for it if you are skilled to do it..
Take the motor apart and check to make sure the bearings are stiff in the mount first. the motor end caps have packing in them you can use a light weight oil like sewing machine oil to saturate the packing, it will keep a good supply of oil to make it last.
Bewertung 0
2 Kommentare:
This only applies to motors that have worn out bearings, I use to service refrigerators for Sears, they have a lot of shaded pole motors. Back then they were not low quality made in China crap so the bearings coming loose causing this same problem only happened when the bearings wore out. Although they did make better motors, they never oiled the packing good enough to last as long as they should have, always soak the bearing packing with zoom oil if you have it apart
von
I meant to say the symptoms of a loose bearing in the housing causes the same issue that prevents the motor from turning that having worn bearings causes, in days when things were made in the USA I never saw a bearing come out of it's housing so the symptoms of the motor locking up because the gap between the stator and armature is gone because the bearing no longer centers it back then was because of worn or dry bearings
Without taking the motor apart and seeing the bearings came out of their mounts, you assume the bearings are worn or need oil, because both lose bearings and worn bearings allows the stator and armature no gap so the 2 magnetic fields stick together and the motor does not turn
von
Is this the culprit? The YJ58 bearing?
Bewertung 0
1 Kommentar:
Absolutely. The bronze bushing popped out of that cast housing on both the front and the rear. There's like a 6 finger flower shaped spring clip that holds it to the housing. Since the rear one is removable; I was able to press that one back into shape and that was enough to straighten out the shaft and keep it true enough to keep from touching the stator and seizing up.
von
How were you able to remove the screws? They're facing the wrong way. Obviously intentional.
Bewertung 0
The motor has cast aluminum brackets on each end that house a brass bearing that is like a ball with a hole in it for the motor shaft. The bearing fits in the housing and is held in by a thin flexing star washer that when the motor was made, after the bearing was placed in the housing, the star washer was pressed in, the washer bows inwards so the star teeth on the outside dig into the housing to hold the bearing in place. They did not make the recess deep enough so the star washer pops out allowing the bearing to be loose which makes the motor stator stick to the armature instead of spin,
I took my motor out trashed the star washer and took a small drill bit and drilled through the housing lip where the star washer was, on each side of the bearing. I had some stiff wire that was around 30 thousandths of an inch I ran through the 4 holes, one wire across one side of the bearing and one wire across the other side of the bearing then bent the wires on each end to keep them in place. So the bearing was held in place and will never slip out again. I save all kinds of stuff and I had this old Harbor freight bug zapper tennis wand, it quit working so I salvaged the mesh wires from it and that is what I used to fix the motor. When you have the motor apart , the bearings have or should have some packing around them in the housing, be sure and soak the packing good with zoom oil while it is apart so the bearings will stay lubricated a long time, from the factory they do not put much oil in them. I am an old Sears Appliance Technician so I have experienced most everything. if any packing is missing you can use tissue or paper towel packed around the bearing. to hold the oil. I have not found replacements for this motor so I just decided to modify it where the problem would not happen again. Another problem with these ovens is getting this E5 code, they say you can reset it by unplugging it. I found that if that does not work it means there is a bad connecting in the circuit. I found that out by hitting the oven above the control panel as I plugged it in. The vibration from hitting it made the connection make contact and the oven started working.
I had taken it apart before to check the triac they say is the problem but it was okay, after unplugging and plugging back in a connector it started working. The triac is like a switching thermostat for AC voltage, when there is an open circuit in that part due to a bad connection, it will throw the e 5 code. If you take it apart with it unplugged, you can move one wire at a time and plug it back in and whichever wire you moved that made it start working is where the bad connection is, also you can unplug and plug back in different connector one at a time while un plugged and when the oven works and does not throw the code when you plug it back in, it was the wire or connector you moved right before it started working that is the problem.
Breville will not tell you this, they know what the design flaw is and want to profit off you sending it back to them to fix it, so most people throw them away. This world is too full of greed anymore, a Company makes an appliance with a design flaw they can profit from and they won't tell you . Most people are not that technical, but for the rest of us it would be nice if they pointed you to the problem in the design. I mean they designed the thing to throw an error code, so if they went to that trouble, they must have known the appliance had a design flaw to reference a code number to it.
They probably outsourced the fan motor and most likely thanks to Politicians working for Corporations, they are all crappy made in China, not like when I worked at Sears decades ago before China made everything and we did not have these issues in new appliances. Corporations make a lot more money using Chinese slave labor wages as money we pay for everything now goes to build China's military when there plan is to Rule the world. Our Politicians suck selling us out, mostly republicans are supporting corporations and billionaires, it was not like this back in the 1970s and early 1980s. Reagan started this crap.
Bewertung 0
Antwort hinzufügen
Chad Huffman wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 35
Letzte 30 Tage: 150
Insgesamt: 17,207
