Zum Hauptinhalt wechseln
Veröffentlicht am 24. Oktober 2011 / 2,2, 2,4, oder 2,5 GHz Quad-Core Intel Core i7 Prozessor
405 Fragen Alle anzeigen
I can't install mac OS it goes to the white screen but runs Windows 7
Hello there,
I have a MacBook Pro 15” Core i7 2.2 GHz Late 2011. I can't install macOS it goes to the white screen but it runs Windows 7
I want to install macOS High Sierra but after first shut down, it goes to the white screen, Also some times it has thick yellow lines on the screen but I don’t have any problem if I use windows on it.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Your Mac has two graphics systems!
The discreet AMD GPU (DG) has a problem, but your Intel CPU’s Intergraded graphics (IG) services is still working! So what you are encountering is Windows is using the IG services, But your macOS install is trying to use the DG services. There is nothing you can do to fix this other than replacing the logic board. But we can tell the OS to use the IG services to run macOS!
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
After trying many time finally I found my Pendrive had problem with installation of OS by replacing with other one finally I installed OS mac 10.13.6 now it is running very well. I hope nothing happens again.
von
Also I changed the paste termical.
von
So the issue was a bad OS installer! And/or corrupted system firmware which the installer fixed.
von
Antwort hinzufügen
Armin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 211
