Zum Hauptinhalt wechseln
Modell A1311 / Mitte 2010 / 3,06 & 3,2 GHz Core i3 oder 3,6 GHz Core i5 Prozessor
Could I use an I7 870 with it?
I have got an Intel I7 870 like the 27” had, I changed the cpu and it didn’t work, I’d it because of the wattage difference or could I potentially use it (prefer to use it; even with risks involved)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Well, you physically could do it, but you’ll likely burnout your system as the chips TDP is much higher 95W vs 73W
As you can see in reviewing the chips specs you aren’t gaining that much given the risks and costs. I would max the RAM and switch out the HDD for a SSD which will get you more bang for the buck!
Make sure you get a SSD which runs at SATA II (3.0 Gb/s) as an example this is what I would go with Samsung 870 EVO note the interface line, it clearly states support for 3.0 Gb/s (SATA II). Make sure what ever drive you go with states it clearly.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Gavin Gav wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 468
