iPhone with "No Service" after replacing charging port
My phone had issues with the charging port, so I replaced it… However, after making this change, my phone is no longer able to detect my carrier… Everything else is working normally (including my new charging port).
If I reinsert my SIM card I can see my phone carrier for around 10 seconds, then the “No Service” is back. Toggling Airplane mode will always show No Service after searching.
My WiFi is working fine but I’m not able to make calls, text or use my carriers Internet.
Because replacing the charging port in an iPhone 7 involves removing most components from the Phone, I’m assuming something went wrong with the component that is in charge of detecting my carrier while I was taking it out from the iPhone? Sucks to create a new problem after solving another one… :(
What part of the Phone is in charge of dealing with the detection of phone carriers?
Can it be that I may have a loose connection between two components inside my iPhone that could cause this? Or is this right away a phone part that is now broken?
How can I fix it? Is it expensive to fix?
Thank you…
Ist dies eine gute Frage?
