Zum Hauptinhalt wechseln
Das Samsung Galaxy A40 wurde im April 2019 veröffentlicht.
28 Fragen Alle anzeigen
Black Blobs Appearing on Phone Screen, Can't Access Anything
Hi there, I’m kinda pulling my hair out trying to figure out this mess I’ve gotten myself into with my Samsung A40. My phone hit the ground hard by accident and despite no visible cracks, black/purple blobs have started spreading throughout the screen. Worst of all, touch screen functionality has ceased and I’m stuck in the Lock Screen. Rebooting it doesn’t work, which isn’t aided by the fact that the volume buttons don’t work to reboot it in the first place, so I had to run it out of charge to restart it. Alas, the touch screen still won’t function and the blobs are spreading.
I understand there may be damage to the AMOLED display, but I’m no expert on this. I have a lot of files stored internally that I never got around to backing up elsewhere and I’m very scared of losing them. Is there anything I can do to get into the phone and grab my stuff before the whole screen becomes unusable? Should I turn it off until I know what I’m doing? Is there any course of action I should take to help mitigate this problem? Thank you so much for your time.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
chances are that the battery is damaged and has expanded, causing it to push against the underside of the screen. perhaps replacing it will fix it, but you will likely have to replace the screen as well, however those are relatively easy fixes
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
I understand, I'm glad to hear it's hopefully not as unsalvageable as I worried it might be. I'll keep trying to identify the exact issue and if I can't sort out those fixes myself, I'll seek out a repair shop in town that can replace what's broken. Thank you!
von
Antwort hinzufügen
biological frog girl wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 132
