Zum Hauptinhalt wechseln
The HP LaserJet CM1415fnw is a multifunction color printer produced by Hewlett Packard.
Having several paper jams
Every thing seems to be working fine with the printer from a communication point; however, every 2nd or 3rd piece of paper jams as it is coming out. I have check to ensure no paper is clogging port where paper is being dispensed and cannot understands why it wrinkles.
Please advise,
Paul
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
you may need to dig a bit deeper. there is a roller that rolls the paper through on most printers. Some times there is 2-3 of them. And it could be at any of those that is the problem. I believe on your printer you can pull the back cover off to get a better look at all the rollers. you may have a small piece of torn paper that only comes around and causes issues every so often.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Paul Staples wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 18
Insgesamt: 450
