Why does my monitor turn off but my pc stays on?
My computer was fine for the first 6 months. However after a while it began having some issues, when doing any activities (gaming, school work, YouTube) it would randomly shut off, making a buzzing static noise through my headphones, however my pc would stay on, the only way of fixing the issue was forcing it to shut down by holding down the power button (which I know is bad) it would then turn back on and the monitor would turn blank, any input would disappear. I would have to hold the power button once again, the strange thing is after doing this sometimes my graphics drivers would be removed.
specs:
Ryzen 3 2300x
rx 570
500 watt cooler master psu
16 GB DDR4 ram
Ist dies eine gute Frage?
Hi @joelfathers ,
Have you tried a different monitor (even a TV on HDMI)?
Does it also do this in safe mode? If not then it is a driver problem.
Also run a sfc command to make sure that the system files are all OK
Sounds like a problem with the GPU card if the drivers are being removed when starting again as it is not being detected.
Can you try another GPU card to see if it is the card or the motherboard?
von jayeff
Hey @jayeff
I have tried multiple monitors, and a tv with a hdmi whilst watching films.
I will have to try this in safe mode. But I presume the issue will persist as it happens even in the windows boot up screen.
I do not own another gpu to try this with, I’m a bit sceptical to take it into a repair shop as my last pc that went into one came out corrupt.
Thanks
von Joe Fathe
