Zum Hauptinhalt wechseln
Apples Flaggschiff-Smartphone für 2020 wurde am 13. Oktober angekündigt und kam am 23. Oktober auf den Markt. Dieser Nachfolger des iPhone 11 Pro ist mit einem 6,1 Zoll OLED Display, einem Kamerasystem mit drei Objektiven und LIDAR sowie 5G ausgestattet.
Is there a repair guide for replacing the glass back of the 12 Pro?
Is there a DIY repair for the glass back of the iPhone 12 Pro? I see parts being sold online but I do not see a repair guide on this website.
Ist dies eine gute Frage?
Bewertung 7
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
There will likely be one in the future on iFixit, however it's not really an easy process at the moment so not practical, especially for the DIY repairers.
*EDIT: Just had a quick look and there is a guide that involves the laser machine here
I'm lucky enough to work with a $4000 laser machine that is used to laser off the adhesive between the glass and frame so it can be broken and chipped off slowly. We also have to use specific diagrams when lasering or else risk lasering an antenna from the device. Then the replacement glass is glued on and bonded down.
If you don’t have an expensive laser removing all of the old glass and adhesive is really tricky o do cleanly and if a small piece of glass is left there when the replacement glass is put on, it’ll all shatter and all be for nothing. It’s a pain because of the way Apple has decided to construct the device, but I’d recommend taking it in to a repair shop for this repair as they can maybe do it same day and with all the correct equipment, but without charging as much as Apple might.
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
michrobi wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 19
Insgesamt: 2,578
