Zum Hauptinhalt wechseln
Locate and remove a jammed coin which resulted from a toddler overenthusiastically shoving change into the toy.
2 Fragen Alle anzeigen
How can I fix it?
I found the panda version of it on the street. Its pressure plate is stuck and the panda as well.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
If this is a mechanized device and a coin is jammed, the mechanism is jammed. The may require disassembling the unit to reveal its internal mechanics to examine it up close. Whether gear or levers are used, sometimes its obvious where to reverse the mechanism to unstick the stuck coin. Good luck as this may result in damage as an inexpensive piggy bank. A rocket scientist isn’t needed as most parents have to deal with real world child raising issues more important than rocket science. Parents raise future rocket scientists.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
XxNatalia_UwUxX wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 4
Letzten 30 Tage: 12
Insgesamt: 161
