Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
2690 Fragen Alle anzeigen
iPhone won't charge after battery replacement (red battery icon)
I just bought an new battery but it wouldn't charge after the replacement. I've tried replacing my old battery and it works just fine. The new battery only shows the red battery icon after plugging the charging cable, and won't turn on the phone.I tried measure the voltage but it's normal (3.82v), is there any solution for this?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
If the original battery still lets the phone power up, then it seems like you received a faulty battery. Contact whoever you got the battery from and see if you can get a replacement.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Thanks for replying, I had contacted the seller, still waiting for the reply.
My phone just turned on after 1 night of charging, but it suddenly turned off after I entered my password (2% of battery).
I also want to know the reason why does it charging so slow. Voltage of the battery seems normal( stable 3.82V), and the charging cable, adapter works fine either, so could it be the battery IC failure?
von
@linsyun Faulty batteries can do all sorts of weird things, I would guess that is related.
von
Antwort hinzufügen
syun wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 29
