Zum Hauptinhalt wechseln
A pop-up it's saying it's going to shut down my
A pop-up it's saying it's going to shut down my tablet what can I do
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
A pop-up keeps saying is going to shut down my tablet what can I do to stop this
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi,
What is the model number of the tablet?
Try starting the tablet in safe mode and check if it still happens. Search online for Samsung (inset tablet model number) safe mode to find out how to do it for your model.
If it works OK in safe mode a downloaded app is the cause of the problem. A downloaded app is one that you downloaded and installed on the tablet and didn’t come pre-installed with the tablet. You would need to uninstall each downloaded app one by one and test the tablet in normal mode between each uninstall until it worked OK. When it does then the last downloaded app that was uninstalled was the culprit.
Alternatively you could try downloading, installing and running an anti-malware app (example only) and check if it finds the cause.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
This could also be a virus.
von
Antwort hinzufügen
Carl Roberts wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 19
Insgesamt: 265
