Zum Hauptinhalt wechseln
Eine TV Spielkonsole von Sony Entertainment, auch bekannt als PS4. Sie wurde am 20. Februar 2013 angekündigt und kam am 15. November 2013 auf den Markt.
1697 Fragen Alle anzeigen
Why won't my controller connect?
I got home after a day out went to turn my playstation on and I got a white blinking light, I tried to use another controller and nothing I reset my wifi, my controller, hard reset my PS4, I even left it alone for a few days and nothing but my controller does connect to a different PS4 so it's definetly my PS4 does anybody know what could be wrong with it?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
If you haven't already, plug the controller in using the USB cable.
If this doesn't work, press the reset button the back of the PS4 Controller (from memory I think it is on the right hand side), you will need a pin or something.
If this doesn't work, hold the Ps and share button until the light indicator on the back flashes quickly.
If none of these work, use a keyboard or borrow a ps4 controller, go to settings > devices > Bluetooth, then remove the dual shock controller. I usually restart my ps4 at this point however I don't think it is necessary, go back into the Bluetooth section, your playstation should now search for nearby Bluetooth devices, press the PS button on your controller.
I sometimes find you have to use a combination of the option and the Ps share button bit.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
hanncdas wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 1,286
