Zum Hauptinhalt wechseln
Die Apple Watch Series 1 ist eine Überarbeitung der ursprünglichen Apple Watch, sie wurde am 7. September 2016 angekündigt. Die meisten Teile sind die gleichen wie bei der Series 2
122 Fragen Alle anzeigen
Post-battery replacement, battery no longer charging
Replaced a swollen battery with iFixit’s kit. Was (and continue to be) delighted by the experience. After a little over two weeks of good functionality, the watch no longer charges past 3-4%. It registers once docked, and still communicates with the iPhone — but is no longer a practical device.
Any advice?
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Concidering that the battery was working for a while after the installation, there may be a defect with the battery.
There is also a good chance that the battery is not connected properly. Possibly the data line of the battery which would cause odd issues as you’re describing.
If you still have the old battery, it may still be able to charge a bit. You could use it to confirm that the new battery is at fault if it charges more then 4%. I would try to reconnect the new battery first.
If none of those seems to work, there is a chance of damaged motherboard components, or partial damage to the charging flex cable. These are less likely since the watch was working for at least 2 weeks after installation.
I hope this helps
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
fjd wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 130
