Zum Hauptinhalt wechseln
Die Wi-Fi Version von Apples iPad 6, erschienen im März 2018. Erhältlich mit 32 und 128 GB Speicher. Ausgestattet mit einem 9,7" Retina Display und einem 64-bit A10 Fusion Prozessor.
150 Fragen Alle anzeigen
After replacing the screen, some parts aren’t tactile
Hi,
I replaced an iPad 6 screen but some parts of the screen are not tactile anymore.
Here is an example in Notes, where you can see the two parts that doesn’t work anymore.
FYI Someone gave me this iPad; He forgot it on his car roof and someone drove on it.
Thanks!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I have had this occur in the past with screen replacements. Each time, the issue was at the connector. Under the scope, you could see the pins not connecting securely with the ribbon cable. Not sure that this may be the issue you’re having, but it would be worth checking.
War diese Antwort hilfreich?
Bewertung 1
Thank you for your help!
You were right, the pins were of very low quality, some broke when I opened the screen again.
I just asked for a return & refund.
Bewertung 0
Antwort hinzufügen
Lulucmy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 43
