Zum Hauptinhalt wechseln
70" 1080p 3D LED-LCD HDTV with Wi-Fi
1 Fragen Alle anzeigen
Is it possible to repair a short in a LCD pannel
Every time I would turn on my tv, the screen started flickering and would develop horizontal lines on the screen within 2 seconds. By that time, the screen would dim to black, it would stay like that until power cycled. The LED backlight works fine, and all signals and voltages from the power supply seem strong and fine.
I immediately replaced the t-con and mainboard, but the symptoms stayed the same. I later found the t-con board clicking (relays) multiple times after power-up, corresponding to the screen flickering. Disconnecting the LCD ribbon cables stops the clicking from the t-con board. I think this means that there is a short in the LCD panel itself.
Is it possible to fix shorts in the LCD panel? Replacements seem to be worth more than the tv was initially.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @doppler911,
The short answer is no, they cannot be repaired.
Either the panel is replaced, if you can find one and the price is right, or you advertise the TV as faulty screen - good for parts to try and recoup some of the cost towards a new TV. Working TV boards are always in demand.
Fixing loose vertical tab connections to the screen is sometimes achievable if it is only a vertical line or two that is the problem but even then not if it is internal to the screen itself.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
TheDopplerEffect wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 12
Letzte 30 Tage: 45
Insgesamt: 777
