Zum Hauptinhalt wechseln
2,2 GHz (Turbo Boost bis zu 3,4 GHz) oder 2,5 GHz (Turbo Boost bis zu 3,7 GHz) Quad Core Intel Core i7 Prozessor mit 6MB geteiltem L3 Cache.
465 Fragen Alle anzeigen
Trackpad and mouse click don't work.
Hi, my mid 2014 Pro stopped registering mouse clicks on the trackpad. I then tried a USB mouse but the same happened there. Both trackpad and mouse can move the mouse and I can use mouse keys “I” to navigate the mac.
I have checked the trackpad connector on the inside and it was a bit loose but after properly seating it there were no change in performance. I’ve also checked the batteries but they don’t seem swollen.
Is there anyone who have a clue what could have caused it? I have tried updating to the latest macOS and tried clearing SMC, PRAM and a fresh install.
The trackpad doesn't seem to click in itself either. Can the trackpad block a external mouse from clicking?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
It seems to work both with the trackpad and mouse if I gently lift the trackpad with a razor blade. So a broken trackpad may block a external usb mouse from properly working. Hope this helps anyone else.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Take a cotton swab (Q-Tip) slightly dampen it with 95% or better isopropyl alcohol. carefully wipe the edge to clean the build up of junk which is jamming your trackpad from working.
von
Antwort hinzufügen
Tim G wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 28
