Zum Hauptinhalt wechseln
Model A1224 / Mitte 2007 und Anfang 2008 / 2, 2.4, oder 2.66 GHz Core 2 Duo Prozessor
547 Fragen Alle anzeigen
The ram isn’t detected in slot 0
No matter what I try, I cant get any ram to read to read from slot0. BUT, It does read from slot1. I got it 2nd hand as working, but when I got it, it beeped at me. I swapped the original ram into slot1, and it worked.
Would this be a MoBo issue, or something else? Any help is appreciated.
Thanks, Soup
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
What is the specs of the SO-DIMM's you bought?
This series can only support a max of 6.0 GB so will encounter issues if you try to install 8 GB of RAM (two 4 GB SO-DIMMs).
Try one 4.0 GB SO-DIMM alone in Slot-0 did that work? Then put in one 2.0 GB SO-DIMM in Slot-1
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
I only have two 1gb sticks and one 2gb stick. All of them work in slot1, none work in slot0.
I bought the 2gb IFixit ram for this iMac.
von
@soup244 - Well, I guess you'll need to get a 4 GB SO-DIMM and just live with the single socket.
von
Yeah, guess you’re right. Thanks.
von
Antwort hinzufügen
Soup wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 28
