Zum Hauptinhalt wechseln
Der Acer Nitro 5 AN515-53-55G9 ist ein Laptop für preisbewusste Gamer, welche 2018 auf den Markt kam. Der Laptop verfügt über einen 256 GB SSD Speicher, eine Nvidia GeForce Grafikkarte und einen Intel Core i5 Quad-Core Prozessor zu einem günstigeren Preis als bei den meisten Gaming Laptops.
Why won’t my laptop turn on?
I had this laptop for over a year now, and it randomly just doesn’t turn on. I didn’t use it for 3 days and left it charging and when I want to use it. It didn’t turn on, I unplugged it and plugged it back. Nothing, I tried the battery reset. Still nothing. There is no lights, no motherboard turning on and no fans on. Please help. (Btw this is a AN515-54)
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Can you unplug the battery and press the power button while the laptop is connected to its charger?
von
Einen Kommentar hinzufügen
2 Antworten
If the laptop suddenly doesn't turn on, and there are no lights, then it may not be charged.
Try making sure that all the parts of the AC adapter are securely connected together. Remove the battery and put it back in (if the laptop will allow). Then plug one end of the adapter into the laptop firmly, and plug the other end into a different electrical outlet than before.
If this doesn't work, then replace the adapter first. Then replace the battery.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
I took it to my local Best Buy and they said it is a motherboard issue. I’m probably going to buy a new one. Because the repair cost is very very expensive
von
need to plug the charger into your acer nitro 5 until you hear click sound TWICE, most people were tricked by the first click sound and thought that was enough to plug the charger while in truth it need to plug till the second click sound appear.
Bewertung 0
Antwort hinzufügen
DJSommerTime wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 18
Letzte 30 Tage: 47
Insgesamt: 2,382
